1º scan feito por mim... Relatório
Resultados 1 a 10 de 10
Tópico: 1º scan feito por mim... Relatório
    383
    Padrão 1º scan feito por mim... Relatório
    Boas pessoal! Sou um Homem feliz! Já tenho Vag e fiz hoje um scan á biatura e eis o resultado!
    Saturday,24,July,2010,06:08:40:13314
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E04A230619 Mileage: 97010km/60279miles
    Address 01: Engine Labels: 059-907-401-AKE.lbl
    Part No: 8E0 907 401 J
    Component: 2.5l V6 TDI G000SG 0006
    Coding: 02005
    Shop #: WSC 63351
    Part No: 00006059
    Component: 130 106LC150_1.V79108923482
    WAUZZZ8E04A230619 AUZ6Z0D0032739
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 3429
    Coding: 04455
    Shop #: WSC 06435
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AC
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63351
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00011
    Shop #: WSC 00000
    1 Fault Found:
    01800 - Light Switch (E1)
    27-10 - Implausible Signal - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0011702
    Shop #: WSC 63351 000 00000
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 04041
    Shop #: WSC 63351
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 930 T
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 01101
    Shop #: WSC 00047
    1 Fault Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    49-10 - No Communications - Intermittent
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H44 0650
    Revision: 01S Serial number: AUZBZ7C0003470
    Coding: 0321217
    Shop #: WSC 26184 512 00000
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 06730
    Shop #: WSC 63351
    Part No: 8E1959801B
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E1959802B
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    1 Fault Found:
    01616 - Signal Wire to Interior Monitor
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 63351
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0321217
    Address 76: Park Assist Labels: 8Z0-919-283.lbl
    Part No: 8Z0 919 283 A
    Component: Parkingsyst. A4 RDW D09
    Coding: 00104
    Shop #: WSC 63351
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 A HW: 8P0 862 335 A
    Component: FSE_255x BT H17 0030
    Revision: 00000001 Serial number: 00000000050187
    Coding: 0000895
    End ---------------------------------------------------------------------
    Encontrou uns erros mas eu não pesco nada disto (ainda )!
    Se alguém me puder ajudar agradeço desde já!!!!
    Última edição por QUATTRO_V6; 24-07-2010 às 06:18.
    Chaves
    361
    Padrão Re: 1º scan feito por mim... Relatório
    Bem, esses erros podem ser devido a alguem ter afinado esses sistemas a partir dum sistema não Vag! Qd fui fazer as chaves do meu e codifica-las na audi, os gajos no scan deles tb detectaram 10 ou 12 erros, cheguei num instante á top5, o mecanico esteve a ver e disse-me isso! Agora aí no teu dá-me impressão que o programa confort não está lá muito bem, e não sei o que é Tõrsteuer senão percebia-se melhor esses 3 avisos que aí tens...
    o problema com o turbo é que não aparece aqui em aviso nenhum! vais ter que o levar a limpar!
    pra quando o tal cafezito? pax
    V6 QUATTRO Avatar de lucianorato
    4.826
    1º Coisa que tens que fazer. É apagar esses erros todos e daqui por uns dias fazeres novo Scan. Se os erros continuarem la, é pq tens qq cosia para resolver, senao aparecerem, é pq eram erros antigos.
    383
    Ora bem o único erro que tenho é o espelho antiencadeamento (sensor de luz) que não está a funcionar! Pela discrição não sei se está lá discriminado! Como é que apago os erros? Tenho que fazer novo scan e limpar ou dá pra limpar sem fazer novo scan?
    383
    Citação Mensagem Original de SilverDragon Ver Post
    Esse problema desapareceu quer-me parecer! Mas de qualquer das formas vou mandar limpar! Uma manutenção ao turbo só lhe faz bem! Quando quiseres vamos as caldas tomar um cafezito ou uma mine! Diz algo quando puderes depois combinasse!
    383
    Citação Mensagem Original de lucianorato Ver Post
    Acabei agora mesmo de apagar os erros! Daqui a 2 ou 3 dias vou voltar a fazer o scan a ver se aparecem de novo!
    Eis o relatório:
    Saturday,24,July,2010,18:12:34:13314
    69 75 76 77
    VIN: WAUZZZ8E04A230619 Mileage: 97040km/60297miles
    Coding: 02005
    Shop #: WSC 63351
    Part No: 00006059
    Readiness: 0 0 X X 1
    Coding: 04455
    Shop #: WSC 06435
    Coding: 00000
    Shop #: WSC 63351
    Coding: 00011
    Shop #: WSC 00000
    Coding: 0011702
    Coding: 04041
    Shop #: WSC 63351
    Coding: 01101
    Shop #: WSC 00047
    Coding: 0321217
    Coding: 00001
    Shop #: WSC 00000
    Coding: 06730
    Shop #: WSC 63351
    Part No: 8E1959801B
    Part No: 8E1959802B
    Part No: 8E0959801A
    Part No: 8E0959802A
    Coding: 00060
    Shop #: WSC 63351
    Coding: 0321217
    Coding: 00104
    Shop #: WSC 63351
    Coding: 0000895
    Quando acedo á função 09 CENT ELEC. para por o menu conforto no CB, depois tenho que á função 07 CODING mas depois não aparece mais nada só uma janela com os valores de fábrica! Segundo o manual deveria aparecer o LONG CODING! Onde é que estou a errar? Tem que se fazer o log in?
    Agradeco a ajuda do lucianorato á questão anterior!
    383
    Então pessoal ninguém dá uma ajudinha?
    4.826
    Eu só vejo
    POrtanto nao tens nenhum erro em lado nenhum. Podes andar descançado
    No futuro se aparecem errros, podes consultar a Wikipedia da Ross-Tech para a resulução dos mesmos
    http://wiki.ross-tech.com/wiki/index.php/Main_Page
    383
    Fiz um scan ao carro e tal até ai tá tudo bem.....
    O que eu não percebo é como é que se entra no long coding!
    Por exemplo, para activar a função cornering temos que aceder á função cent. elec e depois ao coding. Aparece uma janela:
    Que é que tenho que fazer aqui para aceder ao long coding?
    383
    Tou a ver que o pessoal anda chateado comigo!!! Se puderem ajudar agradeço!!!
  1. [Dúvida] Relatório de Erros VW Lupo 3L
    Por Shralin no fórum Eletrónica e VAG-COM
    Última Resp.: 13-12-2010, 19:01
  2. Ajuda em relatorio vag-com
    Por estebescaneca no fórum Eletrónica e VAG-COM
    Última Resp.: 01-03-2010, 17:23
  3. Seat alhambra ficha OBD, Ja aqui esta o relatorio com os erros
    Por Vitor Faria no fórum Eletrónica e VAG-COM
    Última Resp.: 13-05-2009, 15:42
  4. Por favor preciso de ajuda a descodificar relatorio vag-com
    Por Pricarti no fórum Eletrónica e VAG-COM
    Última Resp.: 25-08-2008, 21:54
